for a EC-135 800 size I have to setup a gear ratio of 13.8 in the governor - but the maximum value there is 12.7 as I can see so far. Am I doing something wrong or is the gear ratio really restricted to that value?
What can I do? Is it possible to allow bigger values in the next firmware version?
The only idea I have is to set the sensing divider to its maximum of 8 and use a gear ratio of 12.1 - this should give the same RPM. Can this work?
Setup: Pyro 750-45 in combination with a Jive pro 120+ HV, therefore the actual sending divider is 7
