I'm trying to configure my Spirit to use Rescue in combination with a Futaba T7C transmitter.
It seems to work on the bench, but whatever end-point I set on my TX, it's always Head-Lock or Head-Lock with Rescue.
When I go to Stabi->Function and set it to disable, I have Normal from 0-100% and Head-Lock from 0-100%.
How do I configure to fly with the gyro in Normal (not Head-Lock) and be able to use Rescue?
Normal+Rescue possible?
Found my answer sort of here: http://aero-man.spirit-system.com/index ... te_channel
In combination with bank switching it is possible to fly in Normal gyro mode.
In second bank I configured Stabi tab to do Rescue.
Only problem with this is that when I need rescue I need to do two things.
- Switch to second bank
- Press momentary switch to activate rescue.
My Futaba T7C is not very programmable so I need to live with that I guess.
Would be nice if it can be configured in Spirit software.
