Micro Spirit and Goblin 380
scvflyer
Hello service team,
I have smallest spirit system as well - and i would like to use it for Goblin 380 KSE becuase it's tiny and fine. I know - product documentation says "should be used from 130-250".
What did you think about it. Is it possible to use it for this Goblin? What's my risk trying it?
thanks in advance and br Siggi
it should work well. The only risk is that you might loose power as the JST cables could be not up the task. But this is very dependent on used servos.
I recommend to not use BK servos and/or higher BEC voltage to be safe.
scvflyer
Hello serviceteam,
I would like to use MKS HV93 and MKS HV9780, HobbyWing 80 V4 with 7,5 V at BEC output.
Would that be fine ?
thanks in advance and br siggi
It should work well, but we cant guarantee it.
It could work well also on 500 class heli as it was in our testing.
