Change from regular Spirit to Micro Spirit on 250 size Heli
Kluftinger
I want to switch a full installed and functional Spirit system (red) and use it on a bigger heli.
As a replacement I want to use the smaller Micro-Spirit, since it is a 250 size heli.
Can I store the setup files from all three banks and restore them onto the new Micro-Spirit? :?:
The assembly position and the Rx will be the same.
yes you can. It should be ready to fly immediately. You might only need to tweak a few parameters such as gains, pirouette consistency.
Kluftinger
Thanks for the quick answer.
Since this is my first time doing such a change, I'll check all parameters in the software and then do a test flight.
But before the process I'm happy to get your confirmation. 8-)
