Help with Hobbywing SCM please ?
Dawiev
Hi, I need some help / guidance with the wiring to use the HW SCM module please.
I'm using a Spirit Pro, SPM4649T and a HW 200A ESC. Should I connect the throttle lead through the SCM ? Should I take the +, - from the Aux port on the ESC anywhere ?
Attached is the manual for the the SCM module.
RPM_Telemetryen_Manual.pdf
(1.47 MiB) Downloaded 137 times
Dawiev
Bump. Help needed please !
you do not need the SCM module.
But it could improve RPM or telemetry connection.
Unfortunately I can answer your question on monday. I hope it is OK.
Is there any problem you are having right now?
Dawiev
Thanks for the reply.
I get all the telemetry values, except mah consumed.
Monday, no problem. Thanks in advance
Dawiev
Maybe this Monday ? ;) :lol:
I am very sorry for delayed reply.
You can connect it according the manual that you have attached.
Throttle signal can be connected directly to the AUX port of the unit while Telemetry data should be connected through this SCM module.
This module is designed mainly for RPM and Telemetry data ports of the ESC. But if you do not use RPM lead you do not have to connect it anywhere.
