Sab Goblin with Spirit Pro problem
maio
I have a Goblin 700 and the Spirit Pro set with wizard setup. But do not come to take off because the tail starts extremely shaky at higher speed. What must I change that is gone? Have already tried different cyclic gain and Rudder Common Gain values without success.
you have to set Gyro Gain properly. It look like your gain is very high.
You can verify what gain is configured now in the Diagnostic tab. There you should see something like 50% which is recommended for the first flights.
What value you can see there right now?
Karl1081
maio wrote:I have a Goblin 700 and the Spirit Pro set with wizard setup. But do not come to take off because the tail starts extremely shaky at higher speed. What must I change that is gone? Have already tried different cyclic gain and Rudder Common Gain values without success.
Hi
Take the multiplyer down to 1.0 instead of 1.5 as in present for the gob 700. Then gain at around 50 .this should work. I had the same problem and multiplyer at 1.5 was the problem.
