Re: New user of spirit
Posted: Wed 27. Jun 2018 9:13:47
Hi Zoki,
I am sorry for delay, but I returned from trip now and I was unable to reply sooner.
You can also engage some functions which you will select. It only depends on what is assigned. In this way you can for example tune all parameters very quickly to find the best values.
Basically all questions are always answered in the manual, so you can find more details also there.
Yes, usually it is enough to hold it for less than second to recover horizontal position. But to recover good altitude, it can take a longer time. If you will release the switch, it will immediately return to a normal flying mode.Do i need to hold switch until my heli come to normal position and release that switch
It can be used anytime you want to change settings when flying. It can be used for changing between Rescue, Stabilisation, Flying mode.Bank switch is for self level mode?
With this you can assign a parameter and change it from your radio when flying without need of accessing the software.I see on ch 8,9,10 is special1 special2 and special3
For what is that special 1 2 and 3
