Kontronik kolibri 140 telemetry
Butscher
Hi I have a problem with telemetry, I use a jeti rex6 and kontronik kolibri 140 I would like to have spirit and esc telemetry but if I have the spirit via exbus and the controller telemetry on the other ex bus port the spirit telemetry does not work properly. Can I also run kolibri telemetry over spirit?
Gesendet von meinem SM-G950F mit Tapatalk
at the moment no, but it will work very soon directly over Spirit.
Maybe receiver port is configured in some bad way. There are few options how to configure EX BUS port in the receiver. One option is directly dedicated for telemetry sensors.
Butscher
I have tried several receivers, always the same problem.
I have contacted jeti and received an answer: please contact Spirit for help.
T-Dave
Good morning,
is there some news about Kolibri telemetry directly over Spirit?
David
Yes, it will be supported in the upcoming firmware.
In the following days there will be also new telemetry cable which will allow usage of all radios. So it will work also with OpenTX, HoTT and others.
