Update Unit Bootloader very important
Posted: Thu 19. Jul 2018 18:04:57
Hello I would like to give a general suggestion to all, update the bootloader of Unit spirit when you do an update,specifically 2.4.3, because before I had done this update I always had problems of bind, between my DX8 GEN 2 and lot off Spektrum satellites, beyond with the 4649t. I read the end of the manual better,
relating to the spektrum integration part and as soon as I updated the bootloader I had no bind problems.finish problem
So it is important because if the bootloader is NOT updated the bind also with the 4649t is possible the same, but the unit is not Work okay after, cut off esc, radio signal loss etc, I'm convincing that I lost more than once the radio signal on my satellites for this too.
I await confirmation from Tomas.ciao to everyone
Pino
Pino
