[Solved} Spektrum Integration with the new iX12 transmitter
Posted: Mon 23. Jul 2018 16:47:28
by Kluftinger
Does anybody get a connection to the Spirit adjustment (TextGen window) with a Spektrum iX12?
I have everything running smooth and easy with a SPM4649T rx and a DX7g2 tx
With the new Spektrum iX12 I cannot open the Spirit page. Display TextGen is "on"
Any advice?
Kluftinger
Re: Spektrum Integration with the new iX12 transmitter
Posted: Tue 24. Jul 2018 7:07:56
please make sure that your radio is bound to the SPM4649T so that you can see a telemetry signal intensity too.
Did you observed if a telemetry values are displaying?
Posted: Wed 25. Jul 2018 6:34:56
by Kluftinger
Yes, the bind process was finished and I could see flight pack voltage and signal strength.
I did also a distance test because this was the reason to change from a DX7g2 to the iX12.
My DX7g2 got holds with the 4649T rx at 22 m and I'll send it to HH for service in the next days.
The iX12 exceeds with its antenna diversity 42 m since I could not go any futher back.
Unfortunately the iX12 telemetry doesn't support the ESC window either from the HW Platinum V4 25A.
I hop this will be fixed with the next update.
Posted: Wed 25. Jul 2018 17:45:48
by Kluftinger
Today, Spektrum issued a new update: v1.05.00 build93
Telemetry has full function now!
I have access to the Spirit adjustments (TextGen) and the rpm value is there as well.
And even the yellow bars on the frontside are blinking now, while the iX12 is in sleep mode.
If I had ordered it a week later it would have been a smooth and easy start up.
Re: [Solved} Spektrum Integration with the new iX12 transmit
Posted: Wed 25. Jul 2018 17:56:42
Wow, that is great!
But still good timing
