[SOLVED] Elevator bounce
ritchieicu
Hi I'm getting bounce when flipping and stopping hard. Turning the filter up to 3 has made it much better, only bounces once now, I ran out of time today but will try it at its maximum of 4 which i think will cure it. Is it unusual to need to have it so high, or should i be looking somewhere else
High values are rather needed with agressive blades, too soft head dampeners or when your Cyclic Feed Forward value is too high (depends on your servos too).
So the easiest way is to decrease Cyclic Feed Forward, it should be little bit smoother but not so direct.
If value 4 is enough, then it is OK.
ritchieicu
Thanks Tomas I will have a look, please get some more in stock soon :-)
