Position and altitude hold
alchemy66
Is is ok and safe to take off and land with both Geolink options active?
alchemy66
Anyone? I know the manual says dont use any geolink function unless the model is airborne but I fly in coaxial mode as I'm still learning and it would be nice to be able to take off and land in coaxial like I usually do. Has anyone tried it?
Thanks.
Yes, technically it is possible. But it is recommended to turn the features on after 10-20 seconds after GeoLink has steady ON status LED.
If sooner, then the model could try to move little bit off during lift off.
I recommend to try first Position Hold only. And trying to lift off and land, you should try the features in air first.
