[SOLVED] Geomety 6deg setup
ChrisTTian667
Hey,
i am currently setting up the 6deg geometry. But i can't manage it to be 6deg. When i set the value to 90 i have still 7,2deq.
Can anybody explain me which (hardware) parameters i have to change to get the 6deq and maybe why?? The configuration app tolds me, that i may change the hole on the servor arms. But this would be impossible without loosing the 90deg at 0-Pitch.
thanx for your help!
Triabolo|Kosmik 200|XNOVA 4530 XTS|MKS 960/990|Spirit Pro|REX7
Diabolo BE|Kosmik 200|XNOVA 50XX Tareq|REX3
what helicopter it is?
Some models can't achieve ideal geometry setup, but ths is not a problem at all and flying very well.
For example TRex 550 DFC has only about 70, so you can decrease the value.
ChrisTTian667
Aahhh. Ok. Its an Trex 550 FBL V2
Marian
ChrisTTian667 wrote:Aahhh. Ok. Its an Trex 550 FBL V2
To help lower the mechanical gain of the head you can use shorter ball links on the inner swashplate ring. Those ball links where the dfc arms are connected from the main blade grips to. Those shorter ball links can be found in the Trex 700 kit of ball links sold by Align.
