Newbie: some questions at the very beginning
Posted: Wed 22. Aug 2018 3:45:43
first of all thanks to Tomas for his brilliant and outstandig support!
I know Tomas, you are short in time and your are very busy. I tried to keep my questions as short as I could.
1.) Limits Tab: In „Limits“ you can set the Collectiv Pitch Range (+/- 12 degrees) from 32 to 255 points. How do I know about the best length of the servo horns? Which hole of the horn is best to use? I can take short horns, then the Collective Pitch Range in the software has to be higher. Or I can take longer horns, then the collective pitch range has to be fewer. What is best way?
2.) Sensor Tab: When a channel for Gyro Gain function is assigned, I have to configure gyro gain in the JETI DS-24 under „Heli Tuning | Gyro Settings“. This is clear. Is it possible to have the same procedure with cyclic gain? In other words: Is it possible to configure cyclic gain in the JETI DS-24 under „Heli Tuning | Gyro Settings“? (Note: I know that it is possible to modify cyclic gain with JETI integration in the Device Explorer menu. But that’s not my question.)
3.) Diagnostic Tab: For channel 1 (throttle) in my case it is necessary to adjust subtrim and maximum/minimum values in the JETI DS-24 under „Servo Assignment“. Kontronik wants +/- 100% values when programming the ESC. Is this a problem? In other words: I have changed subtrim and servo travel for throttle a little bit in the transmitter. Is this a problem for the ESC? The manual of the Kontronik ESC says that servo travel of throttle has to be standard (for JETI this means +/-100%). Is it a problem if you change subtrim and servo travel for throttle after programming the ESC? Or is it a problem if you change subtrim and servo travel for throttle before programming the ESC? My question: When should I program the ESC? Before changing servo values in the transmitter or afterwards?
4.) Diagnostic Tab: Do I have to adjust servo travel also for „Bank“ so that it shows +/- 100% as the other channels?
5.) I own an electric big full scale three blade LAMA (2 meters). Do you recommend the unit also for such big scale helis? Do you have experiences? (Bavarian demon is often suggested for scale helis with three and more blades.)
6.) Which english forums are best to visit? Your forum, Helifreak and RunRyder are my first choice. Are there other forums where you provide support?
Kind regards
Chris
Kind regards
Chris
