Wifi not saving settings
Van Scott
After making changes to any Channel Mapping within the General Tab and saving them to the unit via Wifi , there is a confirmation that the setting has indeed successfully saved. However if I leave the General Tab and then return , the program is showing the original settings , not the updated ones that I had just changed to.
It only appears to be Channel Mapping and related settings that this is happening with.
Running a DSMX Sat setup.
Could you please help determine what could be causing an issue like this ?
Yes, you have to click the "confirm" button before leaving the Channels.
