Validation on power and geolink
Pking
I have connected a Geolink on a 230S, i changed the ESC from the V1 to the 230S V2, blade did a upgrade on the ESC and now the tail is going great.
I did use the BEC testing feature and had the main motor running without blades and the tail motor was spinning on and off with the swash servos moving and that test passed. No problems and no power loss log messages. (I had some power loss messages earlier and found a defective cable).
I tried as well to have flights with geolink and no power messages in the log after the flight.
If they’re are no power loos messages on the uSpirit and it did not reset, can I assume the geolink has enough voltage and no brownouts?
I am have issues to calibrate the geolink and flight logs on geolink are not always created in the uSpirit. I have the latest 1.01 geolink FW and 2.5.1 spirit FW. It’s connected to à DSMX sat.
Envoyé de mon iPad en utilisant Tapatalk
