[SOLVED] FrSky XSR and Spirit
mirmel
I have problems to connect my Frsky XSR receiver in the right way to use the opentx integration. Telemetry sensors are shown on the transmitter, but I didn't see any parameters to change options via transmitter.
Is it possible to show me the right way to connect the integration cable Frsky XSR -> Spirit? The S-Bus connection works perfectly.
Thank you.......
Greetings from Cologne,
Dirk
Hello Dirk,
yes, you can find the scheme in the sticky thread in the Support section.
You can find it here:
http://spirit-system.com/phpBB3/viewtop ... =20&t=2254
mirmel
I have connect the cables in the right way......
I solved the problem with an firmwareupdate of the receiver. The OpenTx integration works just now perfectly!
Dirk
Thank you for your message!
