Spirit initialization confirm
Posted: Mon 03. Sep 2018 13:43:21
by flyflyfly
I fly a spirit unit (the red one) on an Trex450 DFC and the SPirit Pro unit on an Trex 600EFL Pro.
On the 450 heli the end of initialization is indicated by swahsplate going a few times (3?) straight up and down a small amount.
The 600 heli is configured the same way and the swashplate doesnt go straight up and down. It tilts a few times. Flying and everything is ok. But is there a meaning to this behavior? Should it also go straight?
And no, the rescue mode is not engaged at this moment.
I tried this also out and then the behavior is a bit different with rescue mode accidentally on.
thx in advance!
Kristian
Re: Spirit initialization confirm
Posted: Mon 03. Sep 2018 13:59:08
it mean that the Spirit Pro unit has flight log saved in the memory. By viewing it it will be "fixed".
From the manual:
If there is a saved log in memory, the user is advised with the message “Log from previous flight is available!” and the log from the flight when the problem occurred is opened. For example, when a signal is lost or the power supply failed you can find this in the log. The log from the first flight where the major problem occurred is always saved. If this is not opened, then it will not be overwritten with a newer one. In this state, the user is also notified by different cyclic pitch pump during the initialization process - elevator servo will change it's movement direction.
Posted: Mon 03. Sep 2018 19:42:21
by flyflyfly
Thats great, thank You!
