Geolink return to ....not home :(
Posted: Tue 04. Sep 2018 21:41:53
Hi All (Specifically Tomas
I had a disturbing instance with my Geolink this morning and I'm hoping to be able to figure out what happened so that it doesn't happen again in the future.
I start every flight with my geolink by testing the safety features and I did this same this morning: Enabled altitude limit and tested to make sure it worked, tested the bailout function, and then tested return to home. When I enabled RTH, the heli immediately started flying off to my left, so i quickly switched it back to manual flight. I then realized that I needed to re-set it as the last time i flew was at a different field. So, I landed and did a RTH reset from the transmitter, took off again, flew about 50' away, and then tested RTH: the model returned to my location and stopped exactly as expected, so i commenced flying as usual
About 2 minutes later I engaged RTH from a couple hundred feet away... and it took off in a completely different direction. I waited 2 seconds or so and finally just killed the motor as the heli was nearing a road and I was having difficulty making out what direction it was facing. Needless to say it didn't end well, but most of my electronics seem to be still intact.
I've been using the Geolink with great success for a couple months now and have had no issues whatsoever with it until now. Is there a way I can troubleshoot what happened here? I'm very curious where the signal was sending my model as it was neither my previous flying location nor the location that i set it to minutes before. It's been my personal experience that whenever something like this happens it's user error and not a fault with the equipment, but i'm scratching my head on this one...
Thanks!
Thanks!
