[ New Spektrum Multi adapter ]
From today you can order new Spektrum Multi adapter!
This will allow you to connect up to 4 satellites with the Spirit Pro unit. And up to 3 satellites with the smaller Spirit units.
When using GeoLink modules you will be able to use enough satellites from now.
Connection is simple - main cable is connected at the RUD port and the single wire at the AIL pin.
Both additional satellites are powered through dedicated power supply for additional safety. This mean that even in case of complete malfunction including a short of the satellite the second one will be still fully functional.
