Frsky integration plus telemetry sensors
thomas5680
Dear all
I would like to combine the opentx integration with the frsky s-port battery sensor.
How should I wire the the components?
Can I put all in series e.g. Battery-Sensor->Integration-cable->spirit-fbl or do i have to use a Y-cable?
Or do I have to do it in another way?
Thanks for your help.
Best regards
Thomas
you can connect FrSky integration cable and FrSky battery sensor together (parallel connection) by using Y-cable or by soldering all 3 wires.
So that there will be 3 black/brown wires, 3 red, 3 white/orange wires.
FrSky cable at the side of the unit must be unmodified and always connected just at the SYS port.
thomas5680
Thanks Tomas for the fast reply!
Greetings
Thomas
