Spirit Pro Firmware Update+Jeti Device Explorer Problem
sawacs
After updating to the latest Spirit Pro firmware, I am no longer able to access the Spirit Pro settings via the device explorer within the transmitter.
When I go into the Jeti Device Explorer and click on the Spirit, which I have done many many times before, the system tries to connected then refreshes the tx screen and I am back where I started which is in the device explorer with the Spirit entry showing. I can click on the Spirit but never actually get into the system to make changes.
The problem began immediately after updating the Spirit Pro firmware..
Help would be most appreciated!
urgno
I think you have to upgrade the spirit.bin inside the jeti trasmitter
http://spirit-system.com/phpBB3/viewtop ... =20&t=2768
sawacs
Thank you for the prompt reply!
Having an outdated bin file installed in the tx would certainly explain a few things :D
Cheers!
Update: I went back into the Jeti TX and updated the Spirit.bin file and that solved the problem.
Thanks again,
Shawn
