How level is level
Tfmcnellis
I currently use a very precise spirit level layed on the Spirit unit to level it before every flight. I use this because I use Normal Stabilization and rescue. They both work very well. My question is, how precise do I need to be?
drparker151
Great question, I was wondering if the forward tilt of the Oxy skids affects Stabilization and rescue and if so, do I need to level it out during initialization. Then after the swash dance can I let sit with its normal rake before take-off.
If model is within +/- 10° then all will be fine.
Tfmcnellis
Does this mean that if I am within the 10 degrees the stabilization will be accurate/ level?
