Vibration level with HoTT telemetrie
pusher
which vibration values with HoTT telemetry are very good, good, ok, bad...? Is there a chart for that?
Altitude value is pending between 3 and 5
(Fuel value always 100ml ?)
Thank you
rolandk
Hello Pusher,
I had a similar question to vibrations in Hott Telemetry.
This is the link to the post.
Maybe it could help You.
http://spirit-system.com/phpBB3/viewtop ... +telemetry
With best regards
Roland
if the value is under 10 in the most cases the model is fine.
But for precise measurement we recommend to use Spectrum Analyzer. Usually Y axis is the worst.
