Geolink default vert. gain not updating
Van Scott
As the title suggests , after updating my GeoLink to Ver 1.0.2 my unit is still displaying default vert. gain of 100% . It is not updating to the new 80% as expected.
Other features appear to be functioning like new TX defined Geo Fence so the update has been done. It is showing Ver 1.0.2 in the Info Tab as well.
Any idea as what could be the cause of this ?
Running Spektrum/Sat system.
there should be no update from 100 to 80%. This applies only to a new setups, for example when you perform factory reset.
But any firmware will not change a values itself for user. It does not mean 100% gain is wrong. It just mean that we have found that it is better to start with lower gain as the result is better that when gain is too high.
So everything is correct.
