Problem updating Spirit Pro
Andjon070
Hello!
I tryed to update my Spirit Pro from 2.4.3 to 2.5.2 but something Went wrong.
I´ve downloaded the newest firmware from the homepage and changen from .man to .4df.
I connected with the Spirit Pro and started to update but nothing happened for a long time. It said 0% all the time. After a while the program didn´t answer so I had to shut it down but after that the gyro won´t start up. The only thing that happens when i Power it up is that the lamp shortly flashes then nothing more and if I try to connect it can´t be found.
Is it possible to reset to factory settings or how can I do?
Thanks for help!
/Anders Jonsson
did you performed any other successful update previously?
Fortunately there is solution for the issue:
http://manual.spirit-system.com/index.p ... ing_Failed
Andjon070
After a few attempts i successed!
Thanks for the help!
/Anders
