[SOLVED] Montage géolink sur Trex 700 JETI DC16
passe partout
Hello, sorry I do not speak English I use a translator.
I will make it simple.
I mounted the Geolink, it works well but today I lost log traces after a crash of the app on the pc.
The telemetry JETI indicates 1300mAh and the consumption is 4500mAh that since maj of the programs and assembly of the geolink
Cdlt
Bonjour, désolé je ne parle pas anglais j'utilise un traducteur.
Je vais faire simple.
J'ai monté le Géolink, il fonctionne bien mais aujourd'hui j'ai perdu les log des traces suite a un plantage du soft sur le pc.
La télémétrie indique 1300mAh et la consommation est de 4500mAh ça depuis maj des programmes et montage du géolink
Cdlt
can you verify if everything is at the latest version?
Spirit Settings and Spirit firmware should be both at 2.5.2.
GeoLink at 1.0.2.
I dont understand how the log is lost. Can you describe the problem little bit more, please?
What ESC and what receiver you are using?
You can turn off GeoLink and verify if this will make a difference and capacity will be measured correctly.
passe partout
ZeXx86 wrote:Hello,
1>> can you verify if everything is at the latest version?
GeoLink at 1.0.2.
2>> I dont understand how the log is lost. Can you describe the problem little bit more, please?
3>> What ESC and what receiver you are using?
4>> You can turn off GeoLink and verify if this will make a difference and capacity will be measured correctly.
1 >> latest version on Spirit, Geolink and Jeti (* .bin)
2 >> when we are in MAPP when the trace loads, everything disappears and there is only tab 1 and the last accessible.
3 >> ESC Castle Créations EDGE 160 HV (latest version), RX JETI REX 3
4 >> ASAP
Cdlt
LapinFou
Je m'incruste dans la conversation.
Si tu as besoin d'aide pour l'Anglais, je te propose mes services.
I'm just sticking to this topic in order to help "passe partout" for English translations. :)
passe partout
Merci mais pour l'instant ça va pas trop mal, si ça se corse je ferai appel à toi.
passe partout
I filmed the bug with a camera, I have no dedicated software.
The erroneous consumption is +/-270 % with or without Géolink.
In the last flight(theft) the RTH the helicopter left contrary to the registered(recorded) point.
J'ai filmé le bug avec une caméra, je n'ai pas de logiciel dédié.
La consommation erronée est de +/-270 % avec ou sans Géolink.
Au dernier vol le RTH l’hélicoptère est parti à l'opposé du point enregistré.
https://youtu.be/6SHYChP9LO4
thank you very much for the video.
I can see that there is really problem.
When you are observing the flight log there it is closing the viewer because connection is unstable.
This can well explain also why RTH is not working correctly. It seems that connection between Spirit and GeoLink is very bad for some reason.
So I want to ask you, if you are using our supplied GeoLink cable? Or you have some other cable?
When you are viewing flight logs it should never close. Data loading should be always smooth and stable.
It is also possible that in Spirit log you will see messages about bad connection. So when this problem is resolved everything will be good.
So first I recommend to verify the GeoLink cable.
passe partout
Thank you for this feedback
I use the cord provided, but I had cut to make it bigger, I changed places on the helicopter so I cut 220mm and welded cleanly.
Merci de ce retour
J'utilise le cordon fourni, mais je l'avais coupé pour le rendre plus grand, j'ai changé de place sur l'hélicoptère donc j'ai recoupé mis à 220mm et soudé proprement.
Thank you for your message.
Do you have any other similar cable?
If no, we can send you a longer cable. Unfortunately soldering is not good idea even if done properly. Any bigger soldering joint is potential problem because it can pickup nearby signal.
Data there are transferred in high speed so parameters of the cable could change even with small modification.
We can ship you new cable on monday.
passe partout
Ok I understand my stupidity: ° ((
I will order you another cable to make tests, I will keep you informed of the result.
For the erected consumer problem, I confirm that now I have to put a 272% coeficient in the Spirit to have the true value. ?
Good week-end
Edit commanded cable
Ok je comprends ma betise :°((
je vais vous commander un autre cable pour faire des éssais, je vous tiendrai au courant du résultat.
Pour le problème de consommation éronnée, je confirme que maintenant je dois mettre un coeficient de 272% dans le Spirit pour avoir la valeur vraie. ?
Bon WE.
Cable commandé.
Last edited by passe partout on Sat 13. Oct 2018 19:46:02, edited 1 time in total.
