Problem with Futaba, FrSky Integration cable Spirit
Fritz.s
Hello
sorry for my bad english
Futaba - R7008SB - FrSky Integration cable modified-Spirit
Hobbywing SAB 60A Controller - Telem UNI Kabel
My problem
With Futaba T14SG (Roxxy sensors) with fw-2.4.3 everything works perfect.
With Futaba T18SZ (Kontronik sensors) with fw-2.5.2 nothing works.
No function, servos, no function telemetry. No connection anymore.
Tried on 2 helis with the same hardware.
But if I insert the FrSky Integration cable intentionally wrong in the spirit, means the brown and red cable in RUD ........... The Orange cable in ELE ...... so RED and ORANGE reversed use , The servos work, I have a connection to the spark.
But no Kontronik telemetry works.
To a friend of mine, I have installed Futaba T18SZ - Hobbywing 130A - Spirit Pro - FrSky Integration cable - Telem UNI cable - fw-2.5.2, everything works perfectly, as described in the manual.
Finally, a big request, a German manual for the Geo-Link Module, so that I can also recommend it to all my friends who do not speak English.
thank you for your message. We were investigating the issue and interestingly there are few pilots that are unable to make it work with 14SG. While for others it is working also with this radio without any problems.
After few more tests we believe we will have a solution.
Have a nice day!
