after update GeoLink constant blinking
Bischi
After update the 3. GeoLink was the Result a constant blinking. The GeoLink are new out of the Box. Now i have no connections to the GeoLink in the Software. What can i do to fix this Problem?
it should be possible to reflash the GeoLink in Recovery mode.
Recovery mode can be entered even that module appears to be "Not connected".
Then you will just select firmware for flashing and once asked for Recovery mode, select it.
Then you have to reconnect GeoLink quickly and the flashing will start. For this process Spirit Pro unit is recommended - if you have one.
But first, could you describe what kind of blinking you can see? I am asking because speed can determine what problem it is.
Maybe the module is just in Compass calibration mode.
Bischi
I make a mp4 yesterday, but i can not post it. How can i send you the short Video? Its possibile to send a pm?
thank you. You can upload it here:
https://sendvid.com/
Then you can just post generated link here.
Bischi
Thanks, its upload
http://sendvid.com/4z36l4wj
Thank you very much!
This helped a lot.
It look like update was not finished properly. But I will send you private message with instruction to solve the problem.
