native Windows Software does not start / close its process
augur
I am using Windows 8 and like to connect to the unit via Wlan. But the software does not start correctly after entering the IP (hangs with the splash screen) and also the process does not stop after closing the software before the change. Actually using the Web-Interface but as I understand no firmware updated are possible with it.
Cheers,
Nils
augur
Hi.
Bluetooth should still be disabled, have connected the spirit successfully by USB before. But I will check again. The issue comes up until I entered the WiFi Adress.
Perhaps it is possible for future release to go directly to WiFi or enter the port by commandline parameter or something else.
Cheers
Nils
