Spirit Pro does not detect Sbus Receiver every 4th bootup
augur
My Spirit Pro does not detect the Sbus2 receiver 7006SB on rather every 4th bootup. It does not show any warning in the log and also show the "ok" pitch movement. But in the configuration software no movements of the sticks are detected and also the telemetry is not transmitted. The Jive connected to the receiver directly works fine. There was also one case the spirit give full rudder and pos. pitch.
Any ideas about that?
Configuration:
Jive 60HV
Connected for telemetry
Sbus2 Receiver connected with changed Frsky cable (extended to 30cm length)
Regards,
Nils
Please check your private messages.
I have sent you a possible solution.
augur
Solved in newer firmware. Thx
