[SOLVED] WiFi link doesnt auto switch off
raft
I've noticed that WiFi link doesnt switch off automatically at all. The blue led continues blinking and I can see the WiFi network in the available list in my iPhone.
Below setting is enough and after 30 seconds after disconnecting it will switch off, right?
if no device will connect to the AP then it will turn off automatically within 30 seconds after powerup.
Yes, you do not have to set anything else.
raft
if I connect and disconnect, it will again switch off, right?
it's not working that way on my setup. any clues?
No, if you do not connect at all then it will disconnect.
bmnewland
New user here, my new Spirit Pro works great. However still confused on the turn off feature for the WiFi link. I enabled 30s auto shut off, however and as the previous member said after I disconnect and have no WiFi activity for over 30s the blue light is still on and the spirit WiFi still shows up on my WiFi list. Is this normal? I would just like to know if it is really off. Thanks for your help.
The Status LED must turn off. Only then the Wifi-Link is turned off.
Unfortunately the only reason why it is not turning off is either because it is configured to connect to your local Wifi network or any nearbly device is connecting to it.
For this reason it is good to set a password there. In this way nothing unwanted will access it.
bmnewland
Ahhh! I’ll create a password. That should do it. Thanks
bmnewland
Did the password, I disconnect my device, the status light now shuts off after 30s. Thank you for the great help.
Very well! Thank you for the message!
Have a nice day!
