OXY 3 Setup
Kiwi1970
Hallo togehter!
Maybe i have a problem with the setup for the OXY 3
The Oxy 3 has a swashplate 120 CCPM reversed
If I use this in the setup. I get the swash plate in the tap servos (servo reverse) not do work correctly. But if I use the swash plate 120 CCPM I can set this without problems but I have in the tab Advancde Settings set the Collective Direction to reversed. In the tab diagnostic everything is fine and the servos are connected correctly. With this setup, the helicopter flies. But I think this configuration is not correct.
Where is my problem. Maybe someone can give me a tip. or is everything ok?
Thank you and best regards
Robert
OXY3.4ds
(255 Bytes) Downloaded 139 times
Hello Robert,
your problem is in the servo connection.
Very likely you only have to swap CH1 and CH3 servo connectors in the unit. You have to connect it according CCPM 120 diagram.
Then use Servo Reversing in the Servos tab to achieve coherent movement of the swashplate when moving with Collective Pitch.
And that is all. You should never use Advanced/Collective Direction reverse on this model otherwise it will not work correct.
You can also verify if channels in the Diagnostic tab are moving in the right direction. If no, then you have to use channel reversing in your radio.
