Spirit micro or normal for Blade Fusion 270?
azaz44
Or is it just a matter of taste?
It will run with FrSky receiver.
This model is using servos equipped with a standard Servo connectors. So it is easier for you to get Spirit. Then you do not have to change a connectors or to use an adapters.
azaz44
That's true. The only thing that makes me wonder is, it looks like the micro has better CPU and sensor, just like the Spirit Pro. Does this make a noticable difference for such a heli?
Very experienced pilot will notice a difference but in any case you can't tell if one is better or not. They are just different.
