Meaning of LED blink signals after power on
Posted: Mon 26. Nov 2018 11:40:01
by Carthago
what is the meaning of the different LED blink signals after power on?
Is there anywhere a listing of all the possibilities?
Thanks,
Toni
Re: Meaning of LED blink signals after power on
Posted: Mon 26. Nov 2018 15:29:54
if you mean LED blink of the GeoLink module then yes.
You can find it here:
http://manual.spirit-system.com/index.p ... leshooting
Posted: Mon 26. Nov 2018 15:54:22
by Carthago
Hello Tomáš,
actually I meant the LED of Spirit / Spirit pro - I couldn't find out much about it.
For example in some cases it glows slowly up and down after power up and then keeps on lighting, but "correct" flying is possible anyway (??).
I think normal behavior should be "LED off" after successful startup.
So a list of possible signals would be helpful I think.
Kind regards,
Toni
Posted: Tue 27. Nov 2018 8:58:22
the unit has no different LED blink signals in a normal operation.
So for this reason there is no table mentioned.
It should always pulsate at the initialization and then should be always On.
The only change could occur when you start the Spirit Settings and doing some tweaks. Then the status LED will be flashing periodically.
If you are in a special mode - for example Subtrim (tuning) then the LED will change its behavior as well.
But during a normal flying mode it should be always consistent.
Posted: Tue 27. Nov 2018 11:05:41
by Carthago
Hello Tomáš,
thank you for explanation.
It seems to be a special problem here in conjunction with my RX8R pro. I can only get correct behavior when I start one of your LUA scripts before powering up receiver and spirit.
We discussed this issue here a few days ago, let's hope that Frsky will provide a new firmware soon.
Best regards,
Toni
