Uneven positive and negative pitch
Hi
correction with channel pitch is not very correct. I recommend to use Servo travel adjust to fix it precisely.
The reason is Trex 450 mechanics is not very precise. It is quite known phenomenon, but with such settings it could be eliminated quite well.
Be sure Collective channel range is +/-100% in the diagnose tab.
I will try that. The only problem with this is that I can only move each servo individually and by doing so I might shift the swash out of level at maximum throw. Than I would need to remove the head and adjust the servos again to level the swash with swash leveler and than I might have the pitch off again. It is a tedious and cumbersome process unless I am doing something wrong and there is a better way ???
