Telem KONTRONIK v2 cable
Posted: Wed 12. Dec 2018 11:45:31
by spitz_1
Hello Tomas,
thanks for the update 2.6.0.
You have written that you can convert the Kontronik V1 cable to V2 ....
Do you have some photos with the exact pin assignment of the plug?
and on which side in the Spirit pro then must be plugged?
best regards
spitz_1
Re: Telem KONTRONIK v2 cable
Posted: Wed 12. Dec 2018 11:50:46
yes, you need only the JST-Servo adapter.
This adapter must be modified so that it will not have RED wire connected.
Then you will plug the Telem KONTRONIK and JST-Servo together (there is just one possible way) and the JST connector will be connected at the satellite port. So everything else will be same as with Telem KONTRONIK v2 cable.
Single wire output from the Telem KONTRONIK is disconnected.
Posted: Wed 12. Dec 2018 12:32:51
by spitz_1
Hello Tomas,
thanks for the quick response.
the brown cable what is the spirit pro in ELE / PIT / AIL from the telem cable, must also be spun out?
best regards
spitz_1
Posted: Wed 12. Dec 2018 14:54:08
As I written in the previous post it should be disconnected. So it will be unused.
You are welcome!
Posted: Wed 12. Dec 2018 19:13:13
by spitz_1
Thank you Tomas,
I was not sure, my English is only a little basis and then the translated to ....
great thanks for all....
best regards
spitz_1
Posted: Thu 13. Dec 2018 9:22:11
by gerry
Hello Tomas!
Could you please tell me for the Telem KONTRONIK v2 cable, the assignment of the plugs on both sides. On the picture in the shop it is difficult to detect. Or you would have a picture where you can see it?
Greetings Gernot
