[SOLVED] New Sbus Telemetry 2.6.0 - how to setup?
augur
there was a note that the telemetry changed for Sbus or Fasstest. But I cannot find anything about it and also it does not work with old configuration. So how it has to be setup?
Cheers,
Nils
There is nothing different in the FASSTest telemetry. It has only better compatibility.
It is identical with 2.5.2 regarding setup.
augur
Ok. Many values are not transmitted anymore as with my T18MZ before it now changed equal to my T14sg. Will prepare an example tomorrow.
Cheers Nils
augur
If I disconnect the motor wires voltage is not transmitted. I done it for testing. :roll: Until I reconnect the motor correctly main voltage is there. Interesting but so seems not a big problem then. But did not know it before.
Cheers,
Nils
