Using the Aero Rescue Only
davehour
I would like to use the Aero rescue feature only, and has its gyro feature turned off during normal flight.
Is this possible?
Thanks,
David
yes, it is possible when you set two Banks.
First where all Gains in the Sensor tab are set to 0% - for normal flight.
Second where gains are at for example 50% - default value and Stabi/Function is configured to Rescue.
Then you have to only switch between banks.
