Version 1.0.25 released!
Version 1.0.25 was released!
It brings many new features and improvements:
  • Bank support added - it is possible to switch between settings in the unit during flight!
  • Channel assignment - you can freely assign channels to any function you wish.
  • Throttle output - throttle channel output can be obtained directly from the unit for all single line receivers.
  • Rudder gain - in case your gyro gain channel is not assigned to the receiver, you can set gyro gain directly in the software..
  • Geometry correction - automatic geometry correction is even better, thus flight characteristics are improved as well.
  • Secured connection - connection between unit and software is secured with a brand new protocol control.
  • Rudder steering - rudder control algorithm is even more precise.
  • PPM protocol - support for 10ms frame settings.
  • SRXL/SUMD protocol - added support for whole new digital protocol family! This includes Multiplex SRXL, Graupner SUMD, Jeti UDI, etc.
  • LOG notification - in case the unit has saved log in it's memory, you will be notified during initialization process.
  • Signal processing - for operation in an extreme conditions there is extended signal processing.
  • Software improvements - software was improved in various places. Configuration should be more straightforward and seamless.
  • and even more - bug fixes, translation corrections, better protocol support, ...
Updated version 1.0.25.1 released
This version fixes only some minor issues:
  • Language support - better support for diacritic characters with MS Windows.
  • PPM improvements - support for Hitec PPM and better channel calibration.
  • S-Bus improvements - better support for FrSky Tarantis protocol implementation.
Changes from previous version 1.0.24 in your settings:
  • All settings from previous version are untouched. You do not need to re-configure anything.
You can download it from our web pages!
