Has the the "initialised" pitch pump changed in 1.0.25
Mikej
I have now loaded and flown the new 1.0.25 firmware and noticed a change. When the unit does it's "initialisation complete" pitch-pump of the swashplate, my heli now only pumps the elevator servo. Has this changed, or do I have a problem?
Thanks,
Mike
this is new feature which indicate that there is a saved log in the unit - something wrong happened during the flight.
It is described in the manual too.
When you review the log, it is cleared and initialization should be normal.
Mikej
Ah, very neat - thanks.
I hit the ESC's LVC, so that was probably the problem... I'll check the log
Thanks,
Mike
Mikej
ZeXx86 wrote: It is described in the manual too.
I hadn't noticed a new manual .. I'll have a look for it, thanks
No problem.
