Transmit Spirit tuning settings over telemetry
azaz44
I think it would be great if Spirit could send the values, which are set by using a channel over telemetry.
For example, you can assign "Pirouette Consistency" to a channel, so you can tune it in flight. But getting the value is little tricky, because you need to remember where you had your slider, then reproduce same radio slider position while connected to a PC with Spirit running, and then you can see that the perfect value was "155". So now you can fix it to 155.
It would be easier to just have it on screen during flying, sent over telemetry.
