[SOLVED] Question about Telem KONTRONIK v2 cable
Vicente_cgn
Hello!
I want to update my Spirit Pro unit to Version 2.6.1.
As I've understood I can't use my Telem KONTRONIK v1 cable any longer after the update, so I need the v2 version.
My problem is that this cable is only 22cm long but I need at least 35cm.
I searched for an JST-extension but I get offered Mini oder Micro-JST, molex cables and so on. There are so many kinds of jst plugs that I don't know which one would be the right one. Also I don't like extensions at all.
So I wanted to ask if there's a possibility to order a Telem KONTRONIK v2 cable with 35cm length?
Otherwise I would have to use my soldering iron ...
Greetings,
Thomas
you can still use Telem KONTRONIK v1 without any change.
So you do not have to order v2 or make any modification :)
Vicente_cgn
Ah, so I misunderstood this.
That's great news, thank you! :)
In any way, you can easily modify your current cable so that it will work as v2. You will need the JST-Servo adaptor cable.
