Failsafe v2.6.1 not using stored values
ferdey
I am having problem with failsafe values on a Spirit non-pro. I have throttle at 0% and pitch at 50% (0 degrees) and I hit the "set" button for failsafes and save on the backup tab. I have tried this 3 times. The blades are visually at 0 degrees. When I disconnect and test, the blades are noticeably at quite high pitch, nothing like they were when I saved the values. What may cause this?
Thanks,
Rob
it is dependent on your receiver/radio.
Some radios are storing its own Failsafe in the receiver as well.
So there are two failsafes.
You might need to reprogram the failsafe in your radio as well.
To test failsafe from Spirit unit just plug off the RX cable from unit.
