[SOLVED] No telemetry values (Jeti REX3 + HobbyWing v4 Opto)
olibanjoli
Hi
I used a Spirit Pro unit with a Frsky X8R receiver and a Hobbywing 130A v4 Opto ESC. Telemetry and integration was working perfectly.
I switched to Jeti DS16 using a REX3 receiver. I connected everything according to the Jeti Integration wiki page. I can configure the Spirit unit from my TX. But i never receive any telemetry values from the ESC. All the sensors are discovered but i never get any value.
I'm not able to find the mistake i made. Do you have any ideas what could went wrong?
oli
probably you are in the Configuration mode - the Status LED of the uni tis flashing.
You have to close the integration menu if it was entered previously.
olibanjoli
No im not in configuration mode. I double checked that.
olibanjoli
found the mistake :roll:
i also turned the spirit unit 180° when i switched to jeti receiver. so the telemetry cable from the hobbywing esc was not in the primary satelite port :(. turned it back and telemetry is working properly :D
Very well :) Sometimes these issues are happening.
