[SOLVED] after updating spirit rescue doesn't act
matty609
hi guys,
I have been out of helicopters for a while and I am almost forgot everything.
Basically, I never had any problem with my old setting. Yesterday I ve decided to update both firmware and software to the latest version.
Everything seems ok except the rescue which doesn't work anymore.
Waht could be changed?
In the servos screen gyro says head lock 45%. I am not using banks.
Hope someone could help me.
Thank you!
LogoX2
If you are using Special Function to activate Rescue then check your Channel Mapping in the software. If you went to 2.6.0 or 2.6.1 from an earlier version these Functions got reset. This was do allowing the usage of additional channels.
matty609
Thank you so much.
I will try to figure out how to let it work again than..
Cheers
It is enough to reload your settings or just set up the Special Functions in the Channels window. For example Channel 8 to F: Stabi Function.
matty609
ZeXx86 wrote:It is enough to reload your settings or just set up the Special Functions in the Channels window. For example Channel 8 to F: Stabi Function.
thank you so much, now it works! is this enough or is there anything else I need to change? I only assigned stabi function to channel 8.
