Wizard setup - Model Presets are grayed out (not selectable)
Bladecrasher
I'm setting up a Oxy3 Qube and when I stepped through the Wizard and got to the Oxy3 listing, it would not allow me to select it?
Does the size of the unit (Pro, Reg, uSpirit) have any factor in this? I'm using a uSpirit since it's not installed presently.
The computer software shows 2.5.0. When connected, I believe the unit shows 2.5.1.
I could select Oxy2 though, which I did to continue the binding process. I now realize that was an error since the Elev servo is not in the same location. Should I just manually make the other adjustments or re-try the Wizard with a model that has the Elev servo in front of the main shaft?
it is dependent on the unit. Oxy 3 preset is available rather for Spirit and Spirit Pro units. So you are right it is due to size.
But you can freely use Oxy 2 preset and it will work in the same way.
