Tip Over After Update?
Posted: Thu 07. Feb 2019 18:23:53
After the update to 2.6.1 on my Align 470LT I'm having an issue, she wants to tip forward before lift off.
It was flying fine before the update. I have a GeoLink installed but not activated and no, I don't have any Stability enabled. I did save my previous setup and tried using that but it still wants to nose over. I also restored the factory settings and did a complete wizard setup (three different times now) with the same results. I've set up this heli before with a BX and then the Spirit and had no issues, everything is correct setup wise (head geometry/servo throw) but she still doesn't want to fly now. The strange thing is it was fine before the update and it seems to be fine on the bench, the swash moves and responds correctly.......any ideas? I'm sure I'm missing something simple. JW
