WIFI Link Network Problem
tho1
I have a problem with my Spirit Wifi Link module. Have an update to version: 2.6.0 performed, now I will no longer Wi-Fi network available, the blue LED lights permanently.
Is the module defective, or can I reset it?
Greetings Thomas
oh, that is sad. Do you remember if you have configured the Wifi module as Client? Or the settings were unchanged.
The update should not change the behavior normally.
For sure we can reset the module for free, unfortunately sending to us is required.
jjuk
My wifi module also would not connect to the spirit after I did a servo bec test.
After lots of plugging in and out it started working again.
tho1
Ok, I will send the module to you.
Thank you, that would be the easiest way.
