Kontonik to spirit pro connections
Posted: Mon 11. Feb 2019 10:37:33
by Karl1081
Ive just ordered a kontronik 200hv for my upcoming diabolo 700 build. Ill be running governor on the esc. Ill be using spirit pro with 2n dsmx sats. And possibly geolink. Im using mks x8 throughout. My question is , will i enough ports on the spirit pro for both master and slave leads from the kontronik. I undrstand that the master lead will be plugged in to the thtrottle channel on the spirit but am unsure about the slave connection
Thanks for any input on this
Re: Kontonik to spirit pro connections
Posted: Mon 11. Feb 2019 20:17:58
yes, there will be enough ports.
You can connect Slave at the CH0 or AUX2 ports.
If you will also use GeoLink you will need to use the Spektrum adapter V2. Or for 3 satellites you can use the Spektrum Multi Adapter.
Posted: Fri 15. Feb 2019 10:19:10
by Karl1081
ZeXx86 wrote:Hello,
Thanks for the reply , im considering using telemetry with with spirit pro and dx9.
So can you advise on wether its possible to have all of yhe following components instalked in the pro. I have spektrum telemetry rx, 1no dsmx sat geolink and bluetooth module .
Can all components be connected
Posted: Fri 15. Feb 2019 17:12:22
Yes, definitively it is possible.
But you will need:
1) Spektrum Adapter V2 - connected at the RUD port.
2) SPM4649T - cables modified so that you will not use Jeti integration cable - instead you will use normal servo socket and add another one for signal. Powering lead will be connected at the AUX2.
3) Bluetooth module - powered from socket of the SPM4649T.
4) Kontronik Master cable at the AUX1, Slave cable at the CH0 port.
Posted: Fri 15. Feb 2019 22:56:56
by Karl1081
ZeXx86 wrote:Yes, definitively it is possible.
But you will need:
Ok thanks Thomas . Ive got the spektrum adaptor v2 lead allready Ive just ordered the kontronik tele cable from you .is this not required .if not i may have to cancel the order ?
Posted: Mon 18. Feb 2019 8:32:34
Kontronik Telem cable is required only if you would like to have ESC telemetry in your radio.
This is not required for flying but with your setup it can be good advantage.
